Hi All
Whilst on our day out to Llandudno today, the Stag decided to act up
which to be fair to it is pretty unusual. Whilst the engine was running the temperature was fine with the needle in the middle of the gauge. When I came to switch the engine off it then proceeded to dump a load of coolant out of the expansion bottle down onto the road. It did this twice on the run across to Llandudno. As we approached the summit of the Great Orme, the temperature started to climb and kept climbing. By the time I pulled over into a place to park, the needle was almost all the way across
. I popped the bonnet and left the entire thing to cool down whilst we had a picnic and flew Toby's kite. After about an hour I filled the radiator back up (+4 litres) and she started up okay. On our way through Deganwy we got stuck in slow traffic and again the temperature climbed. I pulled over as the gauge again reached the top end. Again I let her cool down and then topped up with 6 litres! We then drove top the beach with no problems. On our way home along the A55 she was fine apart from from when we pulled into a petrol station for some sweets. As soon as I turned the engine off she then dumped water onto the road. We stopped once more on the way home but no coolant appeared and again when we arrived home no coolant appeared.
The engine oil looks fine with no trace of water.
No cloud of steam coming from the exhaust pipe apart from on a cold morning start up.
No water in the Vee.
No water dripping from any of the hoses
Cannot see any external defects with the hoses
Fuel mixture seems okay as the spark plugs are a light brown colour.
Any suggestions as to what is causing the coolant to dump out seconds after I switch the engine off?
Bruce
Bruce
