Hello everybody,
yesterday I replaced the seals on the main brake cylinder of my TR6. I had bought the after market repair set for € 38.00 - so they were not cheap quality.
After dismantling the brake cylinder I found out that the old seals had desintegrated to some soft and slimy substance.
After I had put in the new seals (using some red Girling rubber grease) and refilled the brake system with DOT 4 fluid and bled the system, the brake did not build up any pressure.
Frustrated I drove home to get another seal repair set. When I came back to the garage I tried the brakes again - and they worked. Obviously it took the brake fluid some time to make the seals swell and make them tight.
Of course I now keep wondering, what else the brake fluid will do to the seals.... I hope they do not desintegrate again!
My question now is: Where can I get main brake cylinder seals (new or new old stock), which certainly do not desintegrate with DOT 4 brake fluid? The problem with NOS seals might be that over the years they have aged... I am prepared to pay good money for good quality!
Kind regards - from Germany,
Dieter.
Dieter.
