Up to recently My Stag has been a top starter but now it just will not light up at all.In the past with other cars I have owned this problem has been rectified with a new coil.In the Stag workshop manual it states they are fitted with a 6 v coil but I note mine has a 12 v coil.Am I on the right trail or is there another remedy for this problem?
The Stag Coil setup
GuestTags: None
This confusion of 6v or 12v is very common. Sometimes the explanation just makes it worse, but here goes again:
The stag uses a coil with ballast system. This means that the ballast and the coil share the battery voltage approx 50% each. So the coil only gets about 6 ot 7 volts. The xception to this is when cranking (starting) when the coil should receive a boost to full battery colts, ie 12 to 14 volts.
When you buy a coil, you must ask for a ballast coil. If the coil is just marked 12V standard it is probably not a ballast type.
You can tell by measuring the resistance between the two LT terminals; this should read 1.5 ohms for a ballast coil, or 3 ohms for a non-ballast coil.
BTW: the ballast on most stags is part of the wiring loom and cant be seen. On early cars there is a visible ballast resistor fitted near the coil instead of the loom.
Originally posted by V Mad View Post....should receive a boost to full battery colts, ie 12 to 14 volts.....Originally posted by KOY 23 View PostYes Chris, you are right, there is a lot of confusion. I am confused how the battery voltage of an engine being cranked is 12 to 14 volts....
John.The answer isn't 42, it's 1/137
Guest
Guest
Thanks Chris for your reply. How can I find if the ballast is part of the loom and can I fit a ballast coil if there is a ballast in the loom?
