Hi all,
I got the engine going the other day and it was running well. I noticed the voltmeter was showing about 2-4V. After a while, the engine just died. No spluttering. Fuel in filter, clean, old fuel but had stabiliser added/ pump working (or was), new Weber carb.
I'm thinking the alternator has died, but the battery was proving to be difficult and would drain very quickly on starting (used a battery blanket which helped).
questions:
I read a lot about signs of alternator failure showing as overcharging; is that the regulator part that fails when that happens?
Or! Does it matter which way the wires are attached on the voltmeter? The instrument panel is out so wires may be wrong way round.
Can I damage the alternator by using the battery charger to help start the car?
I will try measuring battery with a multimeter tonight. I've left the battery on charge for now.
Cheers, and thankyou for your wisdom
Tanya
questions:
Tanya
