Oil leak up top
    Oil leak up top
    Hi all,
    Anything to be careful of when removing these bolts and replacing the seals? It looks like I have an oil leak around them, many thanks.
    Tanya
    Tanya: Brit in Canada
    Hi Tanya,
    Are you replacing the cam cover gaskets as well ? If so, replace the half moon seals at the front and back.
    Also, if you're removing the cam covers, put them on a flat surface to check that they're not distorted. This happens when the fixings are overtightened - often in an effort to stop leaks ! - and so be careful not to overtighten.
      Originally posted by SaskStag View Post
      Hi all,
      [ATTACH=CONFIG]21444[/ATTACH]
      Tanya
      Hi Tanya, to answer your question, no there is nothing to be careful with, Julian has bought up some good suggestions to reduce oil leaks from the cam cover area. Can I also suggest you use a sealant around the 4 rubber "D"s. if you change the cam cover gaskets you may want to try the silicone ones, I was told to glue the gaskets to the cam covers with contact adhesive and when they are dry use silicone sealant to seal them onto the heads.
      cheers,
      Raoul
        cheers,
        Raoul
        I always find that vaseline jelly smeared on the cork gaskets helps them seal very well .
        Glenn
          I have new cork gaskets anyway from LD, so I may as well do the whole job and I've ordered new seals, many thanks.
          Tanya
