The Stag is back from the trimmers (only a week late and 33% more expensive than original estimate...) with its new hood fitted. So I can at last start to get some use out of it. One problem (just one? Well one I'd like to sort out quickly
) on which I would appreciate some input.
When I come to start her (with my shiny new starter motor) the car sometimes just clicks - as if there is enough juice in the battery to trip the solenoid but not enough to turn the engine over. However, if I turn off and try it a couple more times the starter kicks in and the engine will turn over happily. That's symptom No 1.
The second symptom is that with the engine turning over, it seems to fire just as I turn the key back from the start position - almost as if there is no spark when the starter is turning or maybe the battery voltage rises enough to produce a spark when its not driving the starter motor. It has lumiation ignition fitted, I can't see and ballast resistor close to the coil.
I half suspect the battery - it shows a not too healthy 12 and a bit volts across its terminals so I suspect that's where the problem is; but has anyone had similar symptoms and found a different solution?
Thanks in anticipation!
Matt
Matt
