Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74 Alternator Help - Stag Owners Club Forum
Alternator Help
    Alternator Help
    Just bought a replacement alternator for my MK2 from Paddocks The Vectron Unit they sent seems to be missing a fourth terminal on the back. The alternator I took out has another spade on the back cover. As the wire missing a connection is also brown can I connect it to one of the other thicke browns. Not happy thought I could get this sorted this morning ready for tomorrow.
    Looking at the wiring diagram all the browns go to the battery. Should I run a wire from this thinner brown to the battery? Mike
      Not seen one of these personally - but typically a modern alternator requires just two connections.
      One (skinny one) to connect to the warning light.
      The rest (big and fat) to the battery.
      The ground connection is via the casing - so no wires needed.
      You may have multiple big terminals on the back of the alternator that are paralleled up anyway.
      4x4 Manual OD Stag
        So shall I just connect the thin brown to the fat brown wire or is that going to cause problems. Mike
          Er, why not phone Paddocks for advice?
            Hi Mike
            You don't need the fourth wire just bend it back and tape it to the others or do a good job and take it out lol
            vince
              Don't you think I did that. They are closed.
                Thanks Bent back it is and going back in .Get this thing on the road before the sun goes. Mike
                  Ok mate, Sorry. I didn't realise they closed Saturday morning. They didn't used to.
                    You could have stuck the thin brown on the fat terminals as it is/was the battery sensing wire and ultimately was connected to battery+ - your new alternator is machine sensed so sorts itself out.
                      That told you Dave
                      Reminds me of another thread posted recently, ask for advice then throw it back in your face
                        Total waste of a glorious day. This F..ing Alternator doesn' t fit or line up . It is not a replacement part as they said it would be. Now weekend buggered. Thank you Paddocks. Do not buy Alternators for your Stag from Paddocks. These are Ford fittings . The bushings included are not long enough to allow the alternator to sit square. So now have to refit old one for the drive tomorrow. I will be asking for a total refund plus, from Paddocks thank god I bought it on a credit card. Mike
                          That told you Dave
                          I don't recall having any advice from Dave. So how could I have thrown it back? Mike
                            That's a shame, the last 2 alternators I've bought came from Paddocks and fitted fine.
                              Do you need the the bracket Paddocks sell if you're removing an older ACR11 unit?
                              Tanya
                              Tanya: Brit in Canada
