Hi all, I need to remove the pressure relief valve and as expected I cannot get it to move (the engine is in situ), I was wondering if anyone has tried to remove it by removing the split pin and then cranking the engine over - as suggested on one of my previous posts. I have a large tray that I can put under the car but I am worried that the ensuing pressure may cause a bit too much mess. I was then going to increase the pressure relief point by adding a washer behind the spring.
Any tales of woe or great success would be gratefully received.
Many thanks as ever
Paul
Many thanks as ever
Paul
Good luck ! Martin.
