Hope this is useful to some folks!
I had read here on the forum that the crank timing marker was not always accurate, so thought I would check mine out. I had also read that it was difficult to gauge TDC of no 2 piston, so in lateral thinking mode, decided to try out my cheapo endoscope camera thing that I got off the bay a while back and then try with a simple DIY 'U' tube of water, which I think might be called a manometer?
Both worked remarkably well :-)
METHOD 1: Endoscope and Laptop
I marked the top of the lense and wire with tippex (it is easy to accidentally rotate the lense and therefore image visible on laptop) and held the lense in place, in no 2 spark plug hole, with a lump of blu-tack. It is possible to get a view of both inlet and exhaust valve and the top of the piston all at the same time.
As the crank is rotated the piston travel can easily be seen. The trick is to look closely at an appropriate mark on the piston crown as it rises and falls in relation to the bottom edge of the image window on the laptop. I therefore used the bottom horizontal edge of the image window as a sort of datum line.
I was surprised how quickly the vertical movement of the piston changed to from up to down btw, I had read that there was a noticable period of crank rotation when no movement occurs, from my experience here, there is hardly any 'slack' period.
Photos of No2 Piston and Valves Captured off Laptop:
Second (U tube) method in next post due to photo limits.........
Keith
Keith
