Engine
    Engine
    Hi All just in the middle of buying a stag engine in surry. I Live in yeovil can anyone help with picking up and delivery to me?.
    Also can someone measure lenght height width and weight (without carbs dissy or starter motor) i am thinking around 200kg
    Many Thanks
    Glenn
    Sorry Glenn but even my bathroom scales don't go that high.
      Hi Glenn,
      As I live fairly close to you I'd be willing to go up and collect it for you - as I've said before, just about anything for a Stag apart from a complete shell will fit in or on my C8 I'd just ask you to pay the fuel if you would.
        I can measure one tonight, will post details when I get home around 9.00pm, can't weight it though
        Gary
          Thank you all
          Julian i will keep you in mind and let you know.
          As i am looking to see about getting it delivered via pallet not sure if we could lift 200kg between us.
          Glenn
            Glenn ,Hight is 540mm from bottom of sump to top of cam covers,width is 540mm across widest part of cam covers and length is 700mm from crank bolt to back of manual adaptor plate or 590mm from front of timing cover to back of adaptor plate.weight is VFH.
            Cheers Steve
              Julian - you could swing by mine and borrow my fold up crane, then drop it back on the way home - hopefully Glenn would have the solution for unloading. ..
                Thanks Russ - over to you Glenn.
                  i was hoping to round up some of the fellow stag owners around Yeovil ??? to give a lift out.
                  Cheers Glenn
                    I can tell you from experience, they are b****y heavy lifting then into the back of a Transit on your own
                      Thank you all but i think we have sorted it just waiting for owner to agree pick up time.
                      Cheers Glenn
                        Measured and generally concur, must get home earlier in future!
                        Gary
                          Gary
                          Thank you Gary
                          cheers
                          Glenn
