I have noticed a minor scratching noise caused by the clutch release bearing just slightly touching the clutch spring surface. Pulling back slightly on the clutch lever stops the noise, and pushing the clutch in to engage the bearing also stops it. New bearing and clutch in there.
So the question is how should the clutch lever work - should it pull back slightly after use to fully disengage the bearing? If so how does it do this? I put on an external spring to try and do this, with limited success.
Or is what I describe just normal, in which case won't this cause wear on the clutch where the bearing presses? The scratching noise being the sound of metal on metal wear.
Jon
Jon
