Question: How would you know looking at the relief valve spring if it has weakened?
The transfer housing area is covered in oil and associated muck, so I assume that is where the leak is. However I have chickened out for the present as I’m not quite sure how to go about removing it. A 9/16 spanner fits the bolt, but with the switch and gauge fitting there is no real room to get a purchase on it and I don’t want to round it. I can get a socket on it, but not the socket wrench.
To get more access, should I first undo (from top I assume) the capillary union, disconnect the switch and then undo the fitting or maybe just undo the switch?
Any advice would be welcome. I’m done for the day. It's bar night at the local café.
Oops, one more question:
The advice on here is to prime the pump with Vaseline. I assume that means fill it all up inside with the stuff and then re-fit the pump.
