I would appreciate some advise on what to try next with my alternator issue.
I had an upgraded Wisp alternator fitted with a 3rd party supplied bracket to remount it.
This was installed and working for 18 months without issue.
Last october I started to experience a squeeling noice which initially was there for 3 to 5
minutes then it stopped. I found that if I wedged the alternator against the body of the car
the noice stopped.
I returned the Wisp alternator to the supplier thinking it was faulty bearings. When I came to
fit the new alternator I actually found that the bracket had a crack on the weld so the alternator
was properly secured.
I then received a replacement bracket from the supplier which was also faulty. Misaligned Alternator when fitted. I have waited paitently to get a replacement bracket and eventually decided to order an alternative bracket from another supplier.
I fitted the alternator tonight using the new bracket and to my dismay the noise is still there.
In desperation I swapped the belts from the Steering pump but still the same problem.
Now I am really confused.
I guess the second alternator is ok.
The bracket is now ok.
The belt is ok.
So what can it be?
If I remove the alternator belt there is no noise.
I am wondering if I have another faulty wisp alternator?
Anyone else had problems with these devices?
Could this be the viscous coupling?
Any thoughts
the noice stopped.
The belt is ok.
So what can it be?
Any thoughts
