Thought I wouldgive the old girl a tune up following resolving the issue of the base plate notturning with the vacuum due to the Pertronics screws in the kit being too long.Vacuum working well and new rotor arm fitted too. Thought I would check theairflow to the carbs to make sure they were even before checking fuel mixture.Both appear even now. Timing is set at 14degrees as always rather than 12.
She has alwaysgone like some off a stick but now after playing with the mixture and doingthese jobs, she revs perfectly and smoothly but when driven, if you put yourfoot down quickly, she kicks like mad. I have now set the mixture at 6% and itmakes no difference. Even wound them back a complete turn and same problem. Ican get the engine to miss when idling if you open the throttle quickly
Why did I touchit today and supposed to be using it Friday for a long journey
Any suggestionswelcome please as it must be something that I have touched as the car was finebefore
Andrew
Andrew
