Engine rebuild
    Engine rebuild
    Afternoon all,
    Could someone please advise the average cost of having a engine rebuild done and recommend anyone in Yorkshire.
    Thank you
    Sohail
    Hello,
    At least in Germany we say as a rule of thumb about € 1000.- per cylinder, i. e. 8000.- for a Stag. Maybe this is cheaper in the UK.
    Good luck!
    Dieter.
      HI Sohail,The brother in-law had his rebuilt at mates rates and with parts it was about £2500 ,so if you go with Dieter i dont think he will be far wrong £3500. Have you looked in the wanted section WB50 had one fully rebuilt for sale a couple of weeks ago. Hope you get sorted. Paul.
        Quite a bit of information and ideas on this thread:
        Also:
        Originally posted by dasadrew View Post
        I think you must really find out what is included in that £4000, otherwise it's asking for the opinion of the price of a piece of string.
        The list can be very short (new rings and check other bits for wear) or extremely long. The list of "possibles" which may be included is as long as the parts manual but the company needs to tell you, for example:
        in addition to the standard "crankshaft reground and new shells provided".....
        new valves? what type?
        valve seats cut?
        new guides? what type?
        new oil pump?
        new pistons? or just rings? Be aware that correct pistons for your engines may not be available any more
        new timing gear? what chains?
        what is with ancillaries? Carbs? Dizzie? Water Pump?
        block faced?
        inlet manifold faces skimmed?
        flywheel faced?
        clutch?
        What happens if something untoward is discovered - say a bent con rod. Is the £4000 a cover all eventualities, or could additions creep in?
        Drew
