Just reading the buyers guide to S type Jag in the latest P.C. Replacing the BW 35 with a modern 4 speed auto is £6200 +£2800 fitting. Overhaul of BW 35 is £2675 +£860 fitting.
Makes Clive Tate's ZF conversion a bargain.
Don't tell everyone, I'm still saving up for mine!
What does Clive charge these days for the ZF conversion, just looking at replacing my manual box and it's a grand without fitting so 4 speed auto (car was originally Auto) might be an option, can't put up with this clonking gearbox anymore.
Driver transmissions in Birmingham, rebuilt my BW35 and fitted a new converter for around £1200. The only problem I have is a slight movement in the prop shaft probably caused by a deteriorated rubber buffer in the shaft. Otherwise like new.
