Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74 misfire - Stag Owners Club Forum
misfire
    misfire
    Hi guys
    still have a dam misfire on tick over and if i rev her up to about 2500 revs there is a misfire every second or so, can it be a tight tappet.
    vince
    Apparently a vacuum gauge can show if thats the problem.
      O do tell where and how that works chris, the only other thing i havn't done yet is the dizzy, have you got any.
      vince
        I had this problem a few years ago on one of my engines, must have been in the TR come to think of it, took months to find it.
        I never thought of a vaccuum gauge, swapped all the injection and ignition parts twice, turned out to be a sticking bucket on one of the inlet valves,they were all new, swapped it for the slightly worn one that came out and the problem went away.
        Frustrated the hell out of me, the bucket measured ok, must be something to do with the head.
          Thanks neil, apart from the dizzy ive tried everything else, i did see something in old posts about tappets and misfires, can't find it now.
          Yes driving me nuts now
          vince
            Chopper blade in the distributor has a nick in it. Was the cause of my misfire...
              Yes a nick in your chopper can cause that.
                Hi Vince, have you got one of those little devices that show if a plug is firing ? fits between the plug and the HT lead, try that on each plug in turn and watch for a missing spark, then change the offending plug and/or lead. I'm always in favour of trying cheap and easy first. If the plugs are new, that means nothing, I've come across loads of faulty new ones over the years. Martin.
                  OOH John, how could you ?
                    Ok Martin ill get one and try it first
                    thanks
                    vince
                      Have put a new elecky ignition on and still the same
                      vince
                        Alison said how do you know that
                          Martin how does that thingy show if the plug is faulty if its put between the ht lead and plug
                          vince
                            Met you at Stoneleigh
                              Are you sure it wasn't devils dyke he he
