Looks like its just exhaust wet waste dripping from one of your exhaust joints, which would explain the petrol, leave her over nite with cardboard under her, then start her and see if it happens again
vince
My guess is petrol leaking from underside of tank, seeping through grommet in boot and mixing with underseal before dripping. check the underside of your boot floor.
We supply incontinence products directly to the trade and public. Continence products, discreetly delivered next working day from just 10p each.
My car leaked from all points when I first got her. Front engine oil seal, Rear engine oil seal, gearbox seals, oil cooler, radiator, diff, soft top .......
I had cardboard on the floor in the garage and changed it once a month.
I had very similar small circular drip rings under boot, when fuel tank developed a pin hole, Bob and Sohail. The petrol softened the underseal and tracked along the boot floor.
Cheers Johny
