water pump cover
    water pump cover
    :dude:hi guys, can someone tell me , that if the waterpump cover is damaged on the inside angled machined face, will it leak from this , or does it not matter. thanks paul
    Hi Paul
    It's unlikely to leak, but it's unlikely to pump correctly with a standard pump, dependent on the amount of damageas the angled face forms part of the pumping chamber with the angled vanes on the pump...... of course if you are going electric it's not going to be a problem for you......
    Russ:dude:
      kryten wrote:
      Hi Paul
      Russ:dude:
      Russ have you thought about mastermind ? second round could be the life and works of paul weller!
        Too ashamed of being 40 posts behind.......
          :dude:hi guys, just fitted a new old stock water pump, went well, until i filled with water, it came outthe same rate as i was putting itin !!!. it was coming out of the slot cast in the engine just under the cover,, can anyone tell me whats going on , it can,t be normal for this to happen, i am ready to ship it off to the garage. paul
            Either the new pump didn't have the O rings on the brass body,the O ringswere caught and damaged during fitment of the pumpor the new pump is u/s - sorry Paul, but that's the long and short of it, if the water is coming out of the slot as it can only be the pump or it's seals......
            Russ:dude:
              :dude:hi kryten, i replaced the old pump because it did the same, i can,t belived this one does it as well, so the o rings stop the water coming out of the slot ?. does the brass peice turn or keep still?.i think i will check if anyone living near will come and give me a look. this is giving me the !!!!!!!!. paul
                The brass cage should stay still - there should be thin o rings top and bottom, top to seal coolant from the block bypassing thecage and running out through the holes in the cage and therefore from the block vent passage.
                The lower o ring seals against oil coming up from the crankcase side........
                  :dude:hi guys , i found out whats the problem with the water pump today, the bore is in poor condition, so the seal can not work right, and hold the water , so i either remove the engine and re sleeved the bore, or get a other engine{ i got poor oil pressure with this engine}, or go for a rover v8 or ford v6, which are more usable.i can see i won,t be using this car soon!!.Paul
                    Or you could try bonding the top of the pump to the block with the silicone adhesive that windscreen fitters use to bond in screens- after all, if the block is shagged what have you to lose?
                    The windscreen fitters gunge is dynamite.... seal anything....
                    Russ:dude:
                      hi Russ, i already try-ed a silicone sealer, it worked from slowing the water leak by 90 per cent, thats how i found out it was the bore. is the windscreen silicone better?. if it is i will have a other go !!, third time lucky. can i buy it from stores and is it the same stuff as the windscreen people use?.you right that i have nothing to lose apart from watching the coolant needle incase it goes again. do you knowwhere can i get a engine from??. is there some where who recon,s them. Paul
                        Wander into your local windscreen fitters workshop - explain that you need a small squirt from his gun and why, but you can't bring it to him - he'll most likely give you the remains of his current tube - as I said that stuff if you let it cure correctly for 24 hrs is flippin' dynamite!!
                        you may be lucky and get someone to accept your old lump for exchange but maybe you could find one off ebay from a wrecked car that you can see and hear run...
                        Caveat Emptor though, Paul....
                        Russ
