Power Assisted Steering Belt and Pulley
This topic is closed.
    Hi,
    I started working on my Stag today to fit a new battery clamp, what a faff it is to get the battery out and my current one is smaller the the pucker one so will be replacing.
    I've managed to locate the retaining studs for the clamp but whilst working in that area a couple of daft questions please :
    1) What pulley does the PAS belt go on ?
    2) Can you fit a PAS new belt with the radiator in situ ?
    searching for a Stag
    Hi
    Goes on the small pulley
    Yes can be fitted with rad in situ
    There should be sufficient clearence between battery and power steering pulley (just)
    I need to remove power steering pump to fit a new battery on mine
    Once you have built a ship everything else in life is easy
      Originally posted by 38rover View Post
      Hi
      So does everybody else Sometimes, with aftermarket radiators, fan/rad clearance can be tight. Martin.
        Hi,
        Is the spacer between the left hand side of the pump and the left bracket required for Mk I and Mk 2 Stags
          Hi,
          Thanks all - the smaller pulley it is.
