Where do the pretty wires go?
    So, Ive connected everything to the fuse blade and the relay board, Iam looking for a purple for the glove box light which I cannot find, however, you will see in the picture, I still have 6 wires going to who knows where?
    Two of them, one of which is purple, are on a block connector such as attaches to something like a flasher unit, might it be for the hazard unit which my manual doesn't seem to show, and does every bodies flasher unit just dangle around near the steering column?
    I also attch a picture to ask what folk think about my having painted my wheels gold.
    No idea about the wires but must say i like the paint
    vince
      There are a number of wires near the relay plate that are taped up and do nothing although, offhand, I don't remember which. However, I do have a chart that tells what all the colours do. Can't post it right now on this tablet but will do later on.
      And yes, the flasher unit does dangle although a clip used to be available.
        Hiya Nambo,
        Nice to meet you at the Warren yesterday (sorry I can't remember your name - I have a memory like a sieve).
        I think the connector block is for the hazard lights flasher (assuming yours is late enough to have one fitted). Not sure about the others off the top of my head. I can't see the other wires in the photo I have got of my relay board in front of me
        One of the first ever posts on here was regarding a thought i had about painting my Stag Alloys body coloured - white in my case. I think some one posted saying that I'd get chucked out of the club for that!!! Personally, now i would stay with black, but the gold looks ok.
        The purple wire for the glove box light is on the part of the loom that all the gauges plug into. It runs under the speaker grille, across the top of the heater.
          Hi Nambo,
          Here's a chart that I hope may be of some help to you.
          B Black G Green K Pink LG Light Green
          N Brown O Orange P Purple R Red
          S Slate U Blue W White Y Yellow
          B Earth
          G Ignition Aux--from fuse 3-4 or 19-20
          N Battery - unfused
          P Battery Control - from fuse 1-2
          R RH park/tail/side, license plate lights
          S Window lift relay to window lift CB & overdrive circuit fuse 23-24
          U Headlight feed to main/dip/flash switch
          W Ignition Switch "Ign on"
          Y Fuse 23-24 to overdrive switch
          BP Brake differential pressure (PDWA) switch to brake warning light
          BW Handbrake switch to handbrake warning light
          GB Fuel sender to gauge
          GLG Gearbox/seat belt switch to LH belt switch & RH seat switch
          GN Reverse light switch to lights
          GO Low fuel sender to low fuel warning light
          GP Brake light switch to lights
          GR LH turn signal
          GS Blower switch "high speed" feed to blower motor
          GU Temp sender to gauge
          GW RH turn signal
          GY Blower switch "low speed" feed to low speed resistor
          KW Ballast resistor wire to ignition coil
          LGB Washer pump from steering column switch
          LGK Hazard flasher unit to hazard switch
          LGN Turn flasher unit to steering column switch & hazard switch
          LGO LH belt switch & RH belt switch to Fasten Belt light
          LGS Hazard switch to turn flasher
          NLG Wiper park switch, delay relay circuit
          NY Ignition warning light to alternator field
          PB Horn switch to relay
          PN Ignition controlled relay to fuses 9-10 & 21-22
          PO Interior light switch to RH console and roof lamps
          PR RH door pin switch to RH puddle lamp & interior light switch
          PS LH door pin switch to LH puddle lamp & interior light switch
          PU Blower motor
          PW Interior light switch to LH console & roof lamps, boot & glovebox lamp circuit
          PY Horn relay to horns
          RB Fuse 5-6 to LH front park lamp, LH tail lamp
          RG LH parking lamp supply from master light sw, to ign switch to RH lamps w/ ign on
          RLG Wiper normal speed
          RO Fuse 7-8 to RH tail lamp, RH front park lamp, instrument lights
          RW Dash panel lights from rheostat
          RY Front fog light feed from master light switch
          SG Window lift CB to window switches, RH window switch to RH window motor
          SN LH window lift switch to LH window lift motor
          SP RH window lift switch to RH window lift motor
          SU LH window lift switch to LH window lift motor
          UK LH dip beam
          ULG Wiper high speed
          UR Main/Dip/Flash switch to fuse 15-16 & 17-18, fuse 15-16 to RH dip beam
          US LH main beams
          UW Main/Dip/Flash to fuse 11-12 & 13-14, main beam warning lamp, fuse 13-14 to RH main beams
          WG Heated rear screen switch to heated rear screen & warning lamp
          WK Ignition Switch "Acc" - radio feed
          WLG Wiper delay circuit
          WN Oil pressure sender to light
          WR Ignition Switch "Start" through auto trans inhibit switch to starter solenoid
          WS Tach signal from ignition coil negative terminal
          WU Choke cable switch to choke warning light
          WY Starter solenoid to ignition coil--supplies full voltage to coil while cranking
          YP Overdrive switch through overdrive gearbox switch to overdrive solenoid
            Thanks guys, and that looks like a useful chart Julian though Iam still confused as my hazard connector doesn't have light green and pink but green/yellow and Purple, the purple has continuity with the battery control purple, guess its more fun with the multimeter. This car is going to take a while.
            Thanks for liking the colour Vince, I debated about colour for the 4 years the body took, I was considering Metallic Orange but the painter claimed orange is a difficult colour, plus I wondered if I was getting a bit too old for something too flashy, so figured the Land Rover Cayman Blue was quite refined but still looked pretty.
            Another colour I might have chosen was a blackcurrent, but the painter needed a match that I couldn't find.
              Hi Nambo,
              Both the ROM and the parts book are riddled with errors and also many things changed during the production of the car so you always need to take everything to do with a Strag as a guide . Hope it's helpful though.
                Dave[/QUOTE]
                I can see what they meant
                The gold look alright though.
                Hamstreet Festival of Transport 2013 411 by philipmwsmith, on Flickr
                  When I bought my car my wheels were green (metallic ) on a green body. I didn't think it looked too bad but I preferred the original look and so soon repainted them.
                    Hi Nambo,
                    Try this its helped me out
                    StagColouredWiringDiagram.pdf
                    Paul.
                    1975 TV8, MX5 Sportsnav (Mrs), VW T6
                      Originally posted by Nauts View Post
                      Hi Nambo,
                      [ATTACH=CONFIG]22492[/ATTACH]
                      Paul.
                      I think that is a Mk 2 wiring - Mk 1 was different in quite a few areas. Just in case anyone gets confused !
                      '72 Manual O/d Saffron Yellow
                        That looks useful, cheers Paul.
                        Though I had a cluster of purple wires under the speaker grill, and another lot above the fuse blade, they are all factory capped, as I didnt want to break into them, I just run a wire to the purple from the first fuse which is on the same Purple circuit anyway.
                        So something nice occurred to me today regarding my horn, I have always have a pair of those little red fiamme horns, one wasnt working so good anyway, but I have a nearly new genuine Lucas horn I had taken off my Norton Commando which I decided to use, couldnt find anyway to mount it though without drilling a bigger hole, then I happened across the pair of Norton horn mounting blades, and what do you know, the two holes line up perfectly with the two pre-drilled horn mounting holes on the STag.
                        Tomorow will be an easy and enjoyable day as I will mount all the front lights!
                          Originally posted by StagnJag View Post
                          Hiya Nambo,
                          Now that I have today fitted my instrument cluster, I realise I hadnt understood your comment, thinking you meant the main wiring loom where it runs under the speaker grill, I have indeed found the missing Purple wired on the seperate part of the loom that attaches to the instruments.
                          Still have a few extra ones though!
                            I think I had some spare wires when I rewired mine, a UK car might have the wiring in for air-con? Also in my case, I fitted a '74 loom to a '73 car so had spares left over for the hazard flashers and seat belt warning lights that I did not need.
                            Keith
