Some advice please.
One of my previous threads details my water pump solution. I've now got a new Tony Hart SuperGill and a Davies Craig 115 electric water pump. It has a dual controller which also switches an electric fan on (viscous fan now removed).
With the controller I can choose the target temperature. From 75 upwards in 5 degree increments.
It's currently set at 75 and it manages to keep it just about there but the fan is running quite a lot of the time even when cruising at 70. At 75 the OEM temp gauge is dead centre.
I could set the controller for a higher figure and would then presume it wouldn't be working so hard all the time. However what would be the optimum temperature for it to run at? What are the pros and cons of different settings?
With the controller I can see what is going on as it's mounted in the glove box. It displays the running temperature and fan activity.
Anyone's thoughts would be appreciated.
Chris
(1971 Mk I and very leaky).
Chris
