Just fitted the rejetted Weber Carb I bought of Koy23 and first impressions seem good however I'm not too keen on the throttle linkage setup and wondered if anyone who had fitted the carb to a manual car had come up with a mod or alternative setup to the linkage supplied with the carb?
Weber Carb Throttle Linkage
Originally posted by jusm View Posthey, I've just fitted mine. What were your main concerns on the throttle linkage?
Justin.
Its the U shaped adaptor that the throttle cable fixes to/through that concerns me, it is a poor fit to the carb linkage via the clevis pin and has caught on the adaptor plate a couple of times causing the engine to tick over at high revs. Think mine is an early kit as I bought it second hand and the newer kits may have an improved fitting. I can mod mine but thought if anyone had come up with a viable alternative I would copy it, why reinvent the wheel.
Cheers Davesigpic
Dave.
This was it when fitted to my car, naturally you won't have the left hand part of the linkage. I fitted a return spring as it sometime idled around 2000rpm. I thought the kickdown cable was preventing linkage returning to idle, but thinking about it now it was probably helping. So suggest a return spring is necessary.
Hope you enjoy it.
John.
Originally posted by KOY 23 View Post[ATTACH=CONFIG]22841[/ATTACH]
Dave.
Hope you enjoy it.
John.
Davesigpic
Monarch do a cable for thier Holley which i used on the weber and also fitted a return spring.I came in from the other side and top instead of underneath,cheers Steve
