Whilst I admit the prospect of fitting the engine/Gearbox complete seemed a bit daunting, I was swayed by considering my clutch plate was probably rusted solid to the flywheel after 4 1/2 years.
So took the gearbox off today, unbolted the pressure plate and the clutch plate just fell off with gravity, no rust at all!
"That was a complete waste of time" I mused, but then, purely out of the goodness of my heart, I put a socket on the now revealed 4 flywheel bolts to make sure they where as tight as they looked.
The first one just turned with no pressure and fell out, discolouration revealed it had been completely sheared for a long time, heaven knows what was holding it in.
The next one sheared with a slight pressure on the spanner, fresh metal revealed that had been only sheared by 75%, the other two were fine.
Now, is this a problem on the Stag, maybe the reason the MK2 used 6 bolts?, (I dont know why my MK2 has a four bolt crank?, or does Rimmers get these made in China for I fitted new ones around 95.
I torqued these by the book, though locktite would have meant the threads were not "clean, dry threads", should I have torqued them less?
Now can anybody recommend a supplier who is going to provide strong bolts please?, these were quite easy to drill through, I drilled 4.5 mm holes fairly central and a gnats whisker short of breaking through, Whats the best stud extractor these days?, do you think 4.5 is big enough? those bolts do have loctite on, some special blue stuff.
Iam buggered if they dont come out.
I suppose the crank is too hard for a mortal to drill through to tap for the extra two holes?, my fly wheel had the six.
So what could make them shear in use, they certainly torqued up ok, is it when things get hot and expand its too much for them?
Worried Pete
Worried Pete
