Gearbox Breather - an idea..?
    Having re-built my engine and put the box back I annoyingly still have a tiny leak which I think must be caused by this blocked hole I also didn't know existed before - dammit! I replaced the selector shaft seals and all the others but still there is a very small loss of fluid which I think may be caused by an excess of pressure.
    What I am wondering is if it would be possible/sensible to modify the filler plug so that it is drilled through the centre and has a very small tube sealed into it which is bent so as to vent at the very highest part of the box (or maybe a slightly bigger tube but with a very small say 2mm hole at the top. This way it would be easy to unblock the breather via the small 'door' cut into the LH tunnel.
    I've read that some early TR's had a filler tube which doubled up as a breather pipe (bit like on an auto) so reckon on it being a not too difficult plan;
    Anyone got any thoughts on this?
    Can someone explain to me where the manual gerbox breather is situated
      It is a very small hole in the top cover close to one of the rails, if I remember correctly. Virtually impossible to see, feel or clear with the box in situ sadly. Unlike the diff breather.
        Go for it Mike, easy to reverse if it doesn't work.
        cheers Steve
          You really do need to have small hands and fingers and a small mirror which you can reach up with and turn so that it is looking down on the top of the front part of the gearbox extension - I couldn't see the hole let alone feel it without doing this first.
          The hole is right at the top front of the LHS rail and about 1mm in diameter - no wonder the damn thing is so easily blocked!
          I haven't made a gearbox filler tube extension as I suggested but may do sometime.
              Well done, i'd forgotten that!
