Warning: Undefined array key 313 in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/user.php on line 1
Warning: Undefined array key "online" in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
refurb carbs -
Stag Owners Club Forum
Car failed MOT on C02 Exhaust and decided to expense a refurb set of carbs from Paddocks, (lovely things that everyone at work stroked lovingly - man thing i guess).
before i fitted the new carbs the car was running a little lumpy on cold but fine when warm , however, it will not start at all now. i know the cards will need setting up but all the text says get your car running and then adjust.
My question and request for help is what could be the causes, i've changed the HT leads and plugs, cheched for a spark and the firing order etc but no good. Any tips ...... please.
there is oil in the pots, so i guess that not it. however when i removed the old set of carbs there was a bead of sealant around the old housing which i removed and repalced with a new seal. maybe i should have reseated it with a sealant beed. i'll try that today.
Any other possible causes whilst i've got it all in bits again?
out of interest just fitted old carbs and engine fired into life first time. must be the settings on the refurb carbs. any ideas on how to set up or how difficult?
I think I'd have a word with Paddocks before fiddling with them. From your experiment, there is clearly something not right with the new carbs (even if it is only adjustments) - see what they say before you start dismantling.
Turned out to be the tube assembly inside the top of carbs that opens to let more air in, attached to the needle and the diamphram, had 'stuck' with a slight amount of surface rust. Removed, cleaned,light oiling,refitted,fitted to car and zroom, started first time.
Thanks for all the advise, off for a Whiskey with my dinner.
