Would anyone know where I can buy thrust washers that are 15 or 20th oversize? Usual suppliers (Paddock, Rimmers) have only +5th. I fitted these a few years ago leaving the widest allowable tolerance. Checking again, the end float is out of spec now.
If these can't be bought, do I have any options...getting some made, grinding down 2 x stds, engine out/change the crank :-(
Some direction on this appreciated - thanks
Geoff
Geoff
when fitted it still had a fair bit of movement so we had a moan at them and they arranged for some oversized ones to be made up which put it on the lower end of the tolerance scale. You probably know but a manual car will always wear the thrust bearings more than an auto and it's likely the crank we were sent came from a manual and was cleaned up at the machine shop accordingly. Ironic as I fitted it to an auto.
