At last no drip
    At last no drip
    Well after 4 attempts I have finally got no drip from my rear crankseal this time I used a double lipped seal and alls ok the first attempt was when a new crank was fitted which started leaking not long after the second milothedog kindly did for me (as well as the first)but also started leaking. The third I did but that time once I removed the box I fitted the rad and exhaust and ran it and it was leaking between the seal and speedy sleeve so replace with a ld part but started leaking again 100 miles later so this time I fitted a double lipped seal an success no leak and I've done over 200 miles.how nice it is not having pools of oil over the floor .been using daily in this lovely weather life don't get better than this
    At least you know that the box goes in and out easily what with that and all 8 cylinders working it must be like a new car
      You need to run a British bike or two along with the Stag (I've got a Triumph Bonneville T120 and a BSA A65) - it makes you much more resilient to the odd oil leak
        No drip means empty in Land Rover circles.
          Where did you get the seal from, as mine has always dripped.
          Cheers...Al
            Ian it's nice to have 8 cylinders now surprising how much better it goes now.al i will have to look under some of my old posts some one on here told me where to get the seal about a year or so ago that's when I got it only just got around to fitting it
              stop talking stags and get on with the decorating or di wont let you come out to play on sunday
                Always good when something annoying gets sorted Dean! All settled in up there now?
                  Like an ex wife
                    hello mr marvel yes all sorted loving it some lovely driving roads and very nice people (paul and joss)had to say that he helps me with my car lol
                      Where was the leak evident from? I'm trying to track one from the back of my TV8 MOD car. It's not coming out of the bell housing drain hole but shows up on the engine backplate casting at the clutch slave cylinder.
                      Nick
                      Nick
                        Nick
                        Nick, it could be the core plug at the back of the jack shaft Deans leak was the rear crank seal which for some strange reason seems to have only been cured by fitting a double lipped one.
                          Ta I'd have thought a crankshaft end seal leak would have shown up from the bell housing drain- on a manual anyway.
                          Nick
                          Nick
                            Nick
                            My engine oil filter adaptor leak causes oil to drip down onto the cluch slave cylinder and it runs from there to the lower edge of the bellhousing. Any engine oil leaking from the oil filter/oil pump/transfer housing would accumulate there.
                              Nick
                              Nick, i'm not sure you understood correctly. I'm talking about the core plug in the back of the block at the far end of the jack shaft which is covered by the the bell housing adapter plate.
