My fitted Jackshaft has 003 thou up and down movement, what does the list think of this?, I presume there are no bearings that can be changed?, I also hope that the shaft has a constant thrust in one direction so shouldn't be a problem?
The other movement, if I turn it back and forth, the shaft moves in and out by 012.25 thou, is this acceptable?
(Good job I discovered this before removing my camchain sprocket to remove metal from the back as the sprockets line up perfectly when the jackshaft is rotated in its normal direction!)
Pete
Pete
