Overcharging
    Overcharging
    The wosp high output alternator I fitted about 3 years ago failed on the way to Silverstone today, at idle all was ok and charging about 14.5v, but anything above 2000prm the ignition light would flash and the voltmeter went up in the red.
    The car ran ok, however I was worried about cooking the battery, luckily Roger came to the rescue, lending me his spare alternator for the run home, which probably wouldn't have been so good otherwise, with lights, fan and wipers on because just after we left Silverstone the heavens opened, and we drove 40 miles back in torrential thunderstorm.
    The day however at Silverstone was very good, baking sunshine until 6pm, some fantastic cars and wonderful classic racing.
    Thanks again Roger
    cheers
    If possible just change the voltage regulator on the alternator ,should cost less than 15 pounds ,cheap fix
    Phil
      Phil
      Thanks Phil
      Yes hopefully its just the regulator, any ideas where to get one from?
        Thanks again Roger
        cheers
        Not a problem Dave, glad you got home ok.
          Thanks Phil
          Not seen the alternator myself but - Is it one of these?
          4x4 Manual OD Stag
            Thanks Phil
            Is this the one Dave? http://www.amp-starters.co.uk/produc...istory=related
              As above try eBay or google with the model of your alternator
              Phil
                Dave if you have problems post a photo of your alternator showing its regulator
                Phil
                  Thanks Guys,
                  The alternator itself has no markings or part number on it, the regulator is marked LU1701HD - WT0922 14V, and it does look very similar to this:-
                  and looking at the Wosp web page, this also lists spare regulator for A127IM type,
                  It would be good if the alternator had some kind of marking on it to confirm though
                  cheers
                    My alternator started overcharging on my way to Belgium last year and I had no real option other than to keep going.
                    I too was worried about cooking the battery and it was bubbling over a fair bit. However I covered nearly a thousand miles like that before getting home and swapping the regulator with one kindly dontaed by a fellow forumite (luckily I have a standard type alternator)
                    Result - all fixed and battery still seems to be going ok a year later, although I suspect I have shortened its life expectancy.
                    Hope you get sorted as successfully and easily Dave
                      Thanks Julian
                        Dave does the alternator say a make ie Lucas and amp output
                        Phil
                          Dave I just looked on wasp web site and they list spares for there alternators .have you tried speaking to the supplier who you bought your alternator for as they should be able to obtain a new regulator for you from wasp,or go for the one that 4x4 has put a link to as that looks the same as yours and is rated up 75 amps
                          Phil
                            Phil
                            Many thanks Phil, the alternator doesn't appear to have any markings on it at all, only the regulator. I bought it from Wards in April 2010, so I'll contact them this week
                            cheers
