Hi everyone,
A few weeks ago the inlet manifold gaskets gave way and spewed hot water everywhere. I changed them and all was well, save for a small leak into the vee (arghhh).
I had thought it may have been the water pump gasket but have just nipped the bolts on the thermostat housing to find the bolt is spinning and causing the leak there.
I cant drive now until its all repaired, as the seal has gone altogether.
Anyway, I have a new inlet manifold and set of gaskets on the way for changeover in the week.
Last time I changed the gaskets between the manifold and the heads, I used red sealant (high temp). As I said, all seemed to have worked well. If only I had checked the bolts to the thermo inlet at the same time hey!!
My questions are these;
1. Is red sealant okay to use between manifold and heads or do you guys use anything in particular?
2. Shall I use red or blue sealant with the thermostat inlet gasket?
3. Shall I use red or blue sealant for the water pump housing gasket?
Just want to make sure this is the last time I have to pull it apart for a while and that Im using the absolute best/long lasting methods.
Thanks in anticipation.
Dom
Dom
