Bodyshell rotation jig
    Evening All
    I am still plottiing my reshelling project. With this goal in mind has anybody got a bodyshell rotation jig or know of one that I could borrow/hire?
    Bruce
    Just a thought Bruce..... when I re-shelled my father in laws MGB, I made my own "spit" out of scaffolding that I borrowed - it was very successful and stable and I was able to build it around the car.
    The rotating pivot was 2 short pieces of scaffold welded to a couple of substantial bits of angle iron, which were then bolted to the bumper iron mounts, and it rotated in 2 scaffold clamps.....
    Got any friends that are scaffolders?
      Depends on how much you want to pay, they do a cheaper version. Could probably sell on afterwards. Personally just wary what shape the car would be after tilting, removing and replacing bits and plonking back on the ground.
      http://www.frost.co.uk/item_Detail.a...mp;FrostSubcat=
          Rubce wrote:
          Evening All
          Bruce
          Hi Bruce,
          Depends on how long you will need it for, Keith has one and may rent it out for a short time
          Bruce
            Hi Bruce
            A goodsix months I suppose. I was planning on using if forpreping and and paintingthe underside of the shell and then whilst I fit brake pipes, fuel lines, suspension, electrics etc. All of which will be much easier if I can roll the shell over.
            Bruce
              Hi Kryten
              Unfortunately not, but the idea of being underneath a home made struture like that sends a shiver down my spine. Probably comes from working in a heavy engineering environment and seeing what happens when lifting tackle breaks:shock:
              Bruce
                Blimey, 800 quid when you throw in the adaptor plates. EXPENSIVE:shock:As you say, I could sell it on afterwards but it doesn't help the cashflow.
                Bruce
                  This looks more like it
                  E-bay item : 230267346293
                  Bruce
                    Bruce
                    Looks a bit flimsy to me and you can't lock it from rotatiing.
                    To Quote his website:
                    VEHICLE REQUIREMENTS
                    the shell has to be 90% bare. ie, no running gear and heavy components removed. needs to have sturdy/strong mounting points (the jig wont mount to rotten chassis or crossmembers) "
                      Rubce wrote:
                      Evening All
                      Bruce
                      I have a homemade one that you can have for free,if you pick it up from dorset.it needs some finishing but the frame is sound.I never actually used it.I have since bought a much better one.
                      I can take some pictures and send them to you if you like.
                      Doug.
                        Doug.
                        Hi Doug
                        I have sent you a PM.
                        Bruce
