Brake Servo
    Brake Servo
    Swapped over the brake master cylinder yesterday to cure the dodgy brakes and as I had the servo off thought I'd compare it to a new servo I've had in the cupboard. I got this servo a good few years back with a job lot of factory parts; I initially thought it was for the Stag, but there are a couple of differences:
    1) the master cylinder won't fit. the springs on the master cylinder won't go through the hole.
    2) the center plunger/spigot is missing. it's the bit that goes down the middle of the master cylinder (see attached picture)
    so I wonder if it's from a 2000 or 2500? All the other dimensions are identical. Might as well flog it if it doesn't fit the Stag.
    Stag Servo
    other Servo
