Hello everybody, I have the feeling that the VC in my Stag is not working (properly). When I turn it with a cold engine, it spins about 1/4th of one turn. When the engine is hot, it does only the same. Do you think it is broken? Among my spares I have three more used VCs. How can I check whether they are working properly without having to install them? I was told that you have to store them in an upright Position - which I did. Kind regards, Dieter.
viscous coupling working?
Rear-wheel drive cars with longitudinal engines usually have engine-driven cooling fans. These fans have a thermostatically controlled viscous clutch This clutch is positioned at the hub of the fan, in the airflow coming through the radiator.
There are 2 types, torque type & heat sensitive, I'll put my reply down to the 3 pints of Youngs Special and Wine I had last night before we came home and thinking generically and not specifically StagIt still shouldn't slip too much though as it will reduce it's efficiency.
Last edited by milothedog; 23 August 2013, 07:22.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by jleyton View PostI'm sure I have read in Triumph literature that it is intended to limit the speed of the fan to 2,500 rpm.
Dieter
The viscous fluid allows the fan to slip at higher engine RPM. It reduces power draw. The ram air effect at higher vehicle speeds is theoretically supposed to provide sufficient cooling.
I've never seen anything that indicates that there's any thermal element to the Stag viscous coupling operation.
NickNick
What the thing does is limit torque by slipping, a simple way to limit fan rpms as the torque a fan needs to drive it is directly proportional to its speed (square law IIRC).
The reason it has fins on its external surface is because the action of slipping creates heat, which needs to be conducted away in the airstream.
Viscous couplings in other applications, such as differentials or 4WD couplings, act in the exact opposite way- they slip to begin with, but lock as more torque is transmitted. Confusing old world, ain't it though?Header tanks - you can't beat a bit of bling.
I used to work with the guy that designed the VC, previously he worked for a company named Holsett up in Yorkshire. He did tell me that he held some sort of patent on the fan design. Years ago when my Dolly Sprint VC failed, he said he had some of the fluid at home and offered to repair it!
Keith
