First post from a California lurker.
I'm nearing the end of a full restoration of a 73, building a stripped down abandoned project. I can't seem to get the dist. in its proper place - at TDC, with the rotor pointed at the far coil clamp bolt and the base more or less centered over the attachment bolts and the test light coming on correctly. With the dist so installed, the test light comes on when the base is far off center. Another way to explain: when the dist is installed as above, and I begin to turn the crank, the light comes on some distance past the timing marks. It seems like everything is off one flat on the dist shaft.
Any ideas as to what gives?
Would it be possible to ignore the apparent dislocation and set the plug wires wherever the first firing position happens to be?
Probably all gibberish to the reader, so please weigh with your queries.
John , in San Fran.
John , in San Fran.
Martin.
