Originally posted by Staggard
View Post
That's a good one and not so simple do without making it even more complex. Someone mentioned an electro-mech valve some way back but that's difficult to fit. Still, we might not have to prevent thermal current at all.
The thermal current is not huge in volume, and we mustn't forget that even with an entirely original system, the heater is taking and bypassing coolant to and from the same locations for the heater, it makes little difference to engine warm up at all. A heater and anti-hotspot pump would need to be restricted with a nozzle of equal size to the bypass hole in the standard thermostat.
Also, until quite recently, we have not been able to run with the pump offline, so we don't know the full effects. Perhaps having a pump offline is hardly any different to having the original pump being perturbed by a thermostat cutting off flow, albeit with a little hole in so it can pass some coolant.
If the volume of coolant circulated by thermal current and the little circulation pump (with the main pump offline and no thermostat fitted) is the same as goes through the standard thermostat bypass hole with the original pump fitted and running all of the time, warm up would not be any slower when modified.
