Expensive oil leaks and HGF..... this weeks progress.
    Well here's an update as to the oil leaks and HGF this week.
    I found a leak of coolant coming from the right block, just by the exhaust manifold. Following some great advice on here I have tightened up the cylinder head today, I found that the two rear head bolts needed some tightening (these are above the suspect area) so lets hope its done the trick. If not, its K Seal time.
    As for the oil leak, last week I tracked the leak to the oil pump seal, oil transfer housing seal and to my horror, the main rear gasket to the gearbox. I have been busy obtaining quotes and planning on how i can explain yet more repairs expense, to my wife this week.
    The other day I read on here something that I thought might be worth a shot... a felt washer in the dipstick.
    Guess what, I didn't have one! £1.00 later, 1 minute labour and the leak has stopped. Oil pump/transfer/bell housing dry as a bone! It had clearly dripped all over these and i misdiagnosed the problem. Good job Im not a surgeon.
    Now THATS what this forum is great for... saved me a fortune and put a great big smile on an oily face. Thanks for the advice once again to all.
    Dom
    very lucky, well done Dom
      Great! You wouldn't be the first to not find out where oil is actually coming from. Where it goes to, is the easy bit.
