Stag walnut dash kit
Originally posted by robbo View Posthttp://www.ebay.co.uk/itm/TRIUMPH-ST...-/121171864258
Hi guys.
Has anyone any experience of the above Stag dash kits.
Cheers Rob.
Ian.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by robbo View PostThanks Ian. For around £60 seems to be a bit of a bargain. Iam very tempted.
Cheers Rob.
Hi Rob,
I purchased one of these this year, I agree with all things said so far, the gaps are unaviodable so I painted the edges of mine with a dark brown gloss before I stuck on the panels, now I wonder if they would be more hidden/blended if I would have used black paint ?, the only major downside imo is that they seem to stay 'sticky' to the touch and also appear to mark quite easily, for instance I left a pencil in front of the ashtray and the paint from the pencil stayed stuck to the panel had to use my fingernail to scrape it off, I have tried to polish etc the panels but they still stay sticky to the touch (any ideas gratefully recieved) only one I have not put on yet is the instrument panel, trying to decide weather or not to remove gauges for polishing/re-furbing. Hope this is usefull.
Regards paul.1975 TV8, MX5 Sportsnav (Mrs), VW T6
I fitted this kit to my Stag last year and I can thoroughly recommend it.
Yes, there are some gaps but if you trial fit the panels first, you can anticipate where the gaps will be. These can be disguised after fitting by painting edges with gloss black or brown paint which gives the impression of varnished bezels (if that's not the correct word, you know what I mean.
I've had no problems with tacky varnish. Perhaps Paul left his car parked in direct sun during this very hot period.
Tips:
1. Make sure that the original surface is clean first. I used light grade sandpaper first to give a key then wiped with meths.
2. Take every care to align the stick on veneers. The adhesive is fairly fierce.
3. What you imagine should be the easiest to line up is the glovebox lid because you can offer the veneer up to the lid with the bottom edges on a surface leaving you just to worry about the east/west alignment. I did this and found that the veneer was slightly too big at the top and fouled the dash when I fitted the lid. I trimmed the top of the veneer carefully but still compromised the finish of the edge. Not noticeable to anyone really, but I know it's there.
4. Don't try any shortcuts. Dismantle the parts to be veneered right down to the base item before you apply the veneers.
5. I tried to contact the company after my glovebox experience to see if I could buy a single glovebox veneer. They never answer the phone.
I paid £112 for my kit and am very please with the effect. I don't believe the cost of a proper veneer job can be justified when this option is available.
