Wheel Alignment Specifications
    Hi Everyone, I went to get me Wheel Alignment (tracking) checked today, but they couldn't find the specs on their system. I had taken my workshop manual as a precaution - but couldn't find the details in there either. Does anyone have the necessary toe-in specs etc.? Thanks.
    Had the same problem before...Did they look under Rover on their computer, thats where my guys found it......
    Paul
      1/8" toe in is what I set mine to.
      John.
        Front 1/16" to 1/8" toe in
        Rear 0 to 1/16" toe in
          Hello again, Thanks for your replies. I took the measurements, but their machine a) only operates using degrees (not dimensions) and b) there was no reference to Stags under their Rover heading. Therefore, does anyone have the specifications in degrees? Thanks again. Cheers Frank.
            Frank,
            Front alignment should be between approx 16' to 31' toe in. Or roughly 0.25 to 0.5 degree.
            Rear alignment should be 0 to 16' toe in (0.25 degree)
              Hi Dave,
              Thanks for the reply and the information.
              Frank
