Rebuilding the bottom end
    I am presently having my engine rebuilt by a team of expert engine builders!
    I strongly recommend them, They are 'Gulliver's Engine services' in Lilliput
    Now that's what you would call a "big end"!!
      Getting mine fitted tomorrow. Problem with engine mounts, and they say there may be a slight bonnet bulge.
        I want to see the size of the spark-plugs....
          Aaaah.. That takes me back to when I was in 'real engineering' !
          Al
            Hope they balance it, how big are the pistons???
            jason
              When I was at sea on tankers, we had engines of this sort of size. If there was a problem with one cylinder, the piston could be secured at the top of its stroke and the big end disconnected. We would then run on 5 cylinders. We did this on one 25,000 tonne tanker all the way from the Persian Gulf to Western Australia.
              Pistons were about 1-metre across.
              The last tanker I was on was 280,000 tonnes and powered by a B&W 5-cylinder diesel.
                On the same sort of mind blowing lines ,My Uncle took me on a tour of Ferrybridge power station where he worked .The boilers are hung from the ceiling from huge RSJ's because theyshrink by about a foot when they cool down:shock:.Every thing is big big big and it is a fascinating tour ,open to the public i believe (if it's still going that is as it was coal powered).
                  How did you balance it? Also was it 2 stroke diesel?
                    Yes, 2-stroke diesel. Balancing not a particular problem with an engine that runs at 115rpm flat out! Revs were reduced, if I recall, to about 85rpm. Even so there was some imbalance and at times this could be felt throughout the ship. Colloquially known as 'honeymoon revs' :shock:.
                    Now before any of you have nasty thoughts, my Wife was with me on that trip!
                      That crankshaft was machined by the cutters manufactured by the company I work for.
                      Superb watching it being heated a bearing at a time and shrunk fit together then milled is amazing. I think the crank weighed about 14 tons if I remember correctly.
                      Stuart
                        Bet that took a few oxy-acetylene torches to warm up Stuart
