when fixing the soft top to the car, there is a plate on either side of the car that the hood bolts to, can you replace that plate i think its 622476 in rimmers catalouge
thanks for any help dave
Let me know how yuo do it, mine need changing, the threads are worn out probably been adjusted so many times.
I just fitted a new hood from Jim that fits perfectly, unlike the Rimmers one that was 3 inches to short and cost £300 more, anyway, I had two such threads worn so that you couldnt tighten them, so all I did was fit a stiffnut on the back, theres plenty of room to get your hand in there, check you have enough threads protruding for the nut, else fit slightly longer bolts.
Pete
pete
thats what some body else has done put a nut on the back,but is a pain getting your arm up round the back
dave
Now when I buy Motorcycle gloves, I have to buy XXXL size.
Maybe thats why I found it no problem at all fitting those nuts, my long fingers meant my arms where irrelevant, (except for holding my hands in place).
had a lookat how you would get the soft top fixing plate out today,theres a bracket fixed to the inner rear wing from behind,but if you cut the bracket you wouldnt be able to reweld it back in ( because you would have to weld from behind )so the long shot is ill have to fit a nut on the back of the fixing bolt
dave
easy to weld in dave just get a 250mm hole saw and cut a hole in the outer wing then you can see thru to weld ..............................................
