Another, "Where does this go" thread.
    This bracket doesn't have any mounting holes, apart from the two big ones you see.
    Iam stumped, (as usual).
    Hi Nambo,
    It looks like the tonneau lock plate mate it goes on the underside of the tonneau in the centre.
    regards Simon.
      Order your Plate - Release Catch - Used - 630631U ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
        Thanks Guys, will it become obvious when I offer it up?
        Pete
          Pete
          Depends on the limits of your imagination is one answer.............
          4x4 Manual OD Stag
            designed to push/press/force the hood header rail into the hood well when the cover is closed
              I was going to ask what it does as I cannot discern a difference, I could only get it to fit one way, so I preume the picture is correct?
              Whilst Iam here, the inch holes under the tonneau, should they have grommets?
                Your bracket has an extra 90 degree bend in it that should not be there. See the Rimmers link in a previous post. It should look and fit like this:
                Ross. Perth WA.
                1976 TV8 BW65 Tahiti Blue
                  So mine's not the only one then!
                  John4d
                    Ah ha - have we noticed a common theme though?
                    You've both appear to have metallic paint. Because metallic was never standard on the Stag, I reckon those cunning people at Triumph trained those brackets to turn their bottom lips up at metallic paint
