Hi all, tried this twice last night and it wouldn't let me post??!! So I'll keep it short - just in case. Basically I've replaced the rear shoes and wheel cylinders, fitted braided hoses all round and replaced the front calliper seals, pads, retaining clips etc. The only seals NOT replaced are the square sectioned ones between the two halves of the callipers (none supplied with o'haul kit). I'm using a Gunson auto bleed unit and am getting plenty of air coming through - especially from the rears.There are no apparent leaks evident, although I cannot prove the system is NOT drawing air in anywhere (how do you prove that?). Despite all this I still have no pedal pressure. The PDWA valve is sitting centrally. I believe it points to the master cylinder/servo although I have also replaced these components with supposedly tested parts. Any advice gratefully received if you've come up against this one folks.
Gord
Gord
