hey guys has anyone tried the product K-seal heres a link to it http://www.kseal.com/uk/ i've found water in my oil dip stick and i have alot of white smoke coming from the exhaust so i imagine the head gasket has blown, this product basically says it will fix all leads and seal, great online reviews etc anyone here tried it, only cost £8.99 thanks for any help
K-seal
Hi it's a well know product that is generally thought to offer some degree of stop gap protection. It's not really a long term solution though. My advice would be to get to a garage and get a head gasket sniffer test done.
That way you'd know for certain
From your description though I'd guess you're correct on you're diagnosis.
Others may say different though
We're exactly are you
Gary
I've used it successfully to control a water pump leak. Whether it would be good enugh to deal with a head gaket leak, I'm not sure but I'd be happy to try it.
The only downside I found was cleaning it out afterwards. I flushed and flushed and flushed but still I had lots of copper like residue.
Good luck.
Originally posted by robbo View PostJulian quick question. Did the k seal have an affect on your heater. I have a small leak in to the v and I think is coming from the pump.
Cheers Rob.I ran with the K seal in for about a year I guess.
Originally posted by robbo View PostThanks Julian. I read somewhere that radiators sealers can sometimes block the heater matrix. Did it cure the water pump leak for you.
Rob
cheers From a Yellow Brother"The UK,s 2nd Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
Hi Rob,
I had a fairly significant leak into the vee and the Kseal did stop it. Heater continued to work perfectly but, as I mentioned, when I fixed the pump properly, it was a bit of a job to get all the Kseal flushed out fully.
Based on my experience, I'd recommend Kseal, although only really as a temporary fix.
Rob.
K seal does not block the heater unlike some older leak sealers. When I refilled my cooling system after adding EFI, I had a leak from blanked off outlet on water pump cover, started engine and the K seal that was already in the engine, sealed it completely. Great stuff, and no I don't sell it.
