stag rear wheels sitting at an angle
    hi,my rear wheels are sitting at an angle,what could cause it
    most likely to be the holes in the suspension arms worn oval.
      On my 2.5PI I had some time ago a broken spring caused this problem but only on one side. Unusual if both springs go together but check them and the shock absorbers.
      Rod
        Take a look here : http://www.stag.org.uk/forum/showthr...e-measurements
          as julian said worn holes in the suspension arms,but you can drill them out and fit steel tubes/sleves in to bring it back to original
          dave
            thanks for all replys,going to get my water pump sorted first and then have a go at rear suspension
