Whilst i have the Gearbox out (Yet again) i thought i would tidy up the OD loom with some proper breathable loom tape which i got for the EFI project rather than the nasty electrical tape that is very brittle, now i have removed the link wire Triumph put in there due to not having a inhibitor switch as its a manual.soldered the 2 wires together before they get to the plug so now 2 more bad connection points done away with.
Also found my gearbox leak which was a miss aligned od filter all bent up and preventing the sump plate from seating properly,also a double bodged up home made gasket Why? (Previous,previous owner)
Cheers Steve
Cheers Steve
