Humour me while I ask a question relating to my other hobby - model railways.
A controller I purchased recently in the U.K. proved to be "duff", and a replacement has gone missing in a black hole somewhere.
I am therefore attempting to make my own but my knowledge of electrics is somewhat limited.
What item do I need that I can make or readily buy over here (in Tenerife) that will turn a 16/17 volt supply to one with a range (via knob or slider) from 0 to 12 volts. See attached diagram.
I need to know what "electrical" item I need between points "B" and "D" that will allow me to feed the track from 0 to 12 volts in either direction (ie. forwards or reverse movement of engine). I have an adaptor that converts 220/240 volts to 16/17 volts and just need something between that and the track that outputs 0 to 12 volts in forward or reverse. What is it called that varies the voltage (a regulator?) then I know what to ask for in a local electricians, ideally one with a knob or a slider control on it.
Thank you in advance - although this question does not relate directly to Stags, I am using some spare (no longer required) Stag parts of mine on the model railway I am building - for example cam buckets make ideal model oil refinery storage tanks, and exhaust brackets front and back ends of a "Nissan" hut ("n" scale).
