Hi,
I have been having problems with the stud holding on the Stromberg carbs, it has striped the thread once, so I fitted a helicoil with stud lock etc..., now it looks like it is happening again. The carbs seem to have come slightly loose again resulting in air being sucked in under hard acceleration causing a stutter.
Any advice on getting a better fixing into the inlet manifold ? Has anyone try fitting the stud into the helicoil with something like chemical metal ? My concern is the metal has become too soft with age and the whole manifold will need changing. Or is there any additional fixings that can be made to beef up the single stud.
Any advice gratefully received.
Thanks,
Kevin
Thanks,
Kevin
