"forum addiction!"
    I have now turned the questions I listed into a Poll. Mine is no. 2 by the way.
    Unfortunately I made a spelling mistake in option 8 (should say "stuck" not "stick" but can't find a way of correcting it,
    a normal edit won't bring up the Poll.
      No 1 at home, work and abroad whilst working and on holiday. Totally addicted! :-)
        I suppose the people who don't use the forum very often won't see the poll!
        Tanya
        Tanya: Brit in Canada
        71 Fed Stag, TV8, ZF 4spd auto, EWP and crossed fingers
          I'm a 1. I sneak a peak when I'm at work at least once a day!
          The flaw in this poll is that the people who post more often are more likely to see this post and vote! The ones who only post when their Stag is broken, won't see this until their Stag breaks down!!!
            I look most days off the week. An invaluable resource off onfo. One day i'll use this info to hopefully rebuild my car. Latest target some time late summer 2014 after a 30yr lay-up, steve
              Originally posted by Kevin Garrod View Post
              On a related note when I joined the forum there were maybe a couple of dozen members and now I think there are only 3 longer serving forummers. (Not counting Carl)
              It turns out my assumption was out by a factor of over 10 and there are still a lot of old hands about.
                DJT joined in Nov 2006, is he one of the first non Moderator/Administrators to register on the Forum, or is there someone still on here who can beat that date?
                  As a relative Newbie (I only joined in April 2009), I'm not sure whether I should be embarrassed or proud of my daily posting rate of 3.94 .
                  Does that make me the most addicted on here ?
                  I just hope that there's been some useful posts amongst them all.
                    Wow Julian! I didn't know you were a 'newbie' when I copied you and cut a big hole in my transmission tunnel!
                    (Works though!)
                    Mark.
                      DJT beat me by a month. I assume that's the first version of the forum.
                        That depends if you consider this the second or third version.
                        Who remembers the very first one?
                          Perhaps this thread could be made a sticky at least until the poll ends to give the less frequent users a chance to see it?
                            On looking back the post below appears to be possibly one of the first made back in November 2006 by a guest user.
                            Correct me if I am wrong.
                            24th November 2006, 11:52 #1 grandpascot
                            Guest
                            Being a newish member of the SOG and having only just registered on this new forum may I be the first on this forum to ask for advice. I have a 1978 Stag nearing completion of a nut and bolt restoration. My question is what was the radio that was fitted as standard?
