Hi,
I have to confess I was a bit heavy on the accelerator with the window down, listening to the growl between 1st and 2nd gear tonight.
But as the front lunged down between gears, both main beam headlamps went out. Exactly the same time. The full beam works (only one side but that may have been an old injury). The sidelights work. The fuse is fine.
Given that its a bit wet and cold out there, does anyone have any suggestions where to start?
I would be shocked if its the bulbs but I cant check that tonight. Shocked because they both went at the same time, unless the extra right pedal gave the electrics a supercharged boosting?
Seriously though, wiring or steering control...which one is most likely, are there any 'common faults' to look out for?
Thanks guys
Dom
Thanks guys
Dom
